Einleitung
In order to reach the flash capacitor, you have to remove the front and back panel, the button board and the top cover of the device. Be very careful when you remove these parts.
Was du brauchst
Remove the six 3.5mm Phillips #000 screws.
Rotate the lock away from the camera.
Remove the two plastic spacers between the front and the back panels.
Carefully remove the back panel.
Disconnect the no-fuss ribbon cable by gently pulling it out of the button board.
Lift the capacitor from the assembly.
Disconnect the no-fuss ribbon cable by gently pulling it out of the flash board.
