Zum Hauptinhalt wechseln
Sony Cyber-Shot DSC-W830 Front and Back Panel Replacement
Was du brauchst
  1. Sony Cyber-Shot DSC-W830 Front and Back Panel Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide the lock at the bottom of the camera to "Open".
    • The door to the battery pack is spring loaded.
  2. Sony Cyber-Shot DSC-W830 Front and Back Panel Replacement: Schritt 2, Bild 1 von 1
    • Slide the blue clip up and away from the battery.
  3. Sony Cyber-Shot DSC-W830 Front and Back Panel Replacement: Schritt 3, Bild 1 von 1
    • Remove the battery.
  4. Sony Cyber-Shot DSC-W830 Front and Back Panel Replacement, Front and Back Panel: Schritt 4, Bild 1 von 3 Sony Cyber-Shot DSC-W830 Front and Back Panel Replacement, Front and Back Panel: Schritt 4, Bild 2 von 3 Sony Cyber-Shot DSC-W830 Front and Back Panel Replacement, Front and Back Panel: Schritt 4, Bild 3 von 3
    • Remove the six 3.5mm Phillips #000 screws.
    • Rotate the lock away from the camera.
  5. Sony Cyber-Shot DSC-W830 Front and Back Panel Replacement: Schritt 5, Bild 1 von 3 Sony Cyber-Shot DSC-W830 Front and Back Panel Replacement: Schritt 5, Bild 2 von 3 Sony Cyber-Shot DSC-W830 Front and Back Panel Replacement: Schritt 5, Bild 3 von 3
    • Pry the device open with the plastic opening tool.
    • There are two clips that help prevent the front panel from separating.
  6. Sony Cyber-Shot DSC-W830 Front and Back Panel Replacement: Schritt 6, Bild 1 von 3 Sony Cyber-Shot DSC-W830 Front and Back Panel Replacement: Schritt 6, Bild 2 von 3 Sony Cyber-Shot DSC-W830 Front and Back Panel Replacement: Schritt 6, Bild 3 von 3
    • Remove the two plastic spacers between the front and the back panels.
    • The spacers may fall out when removing the panels.
    • Carefully remove the back panel.
Abschluss
Tong Tang
557 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 17-1, Blackwell Fall 2016 Mitglied von USF Tampa, Team 17-1, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G1
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 15
Insgesamt: 1,101
