Einleitung
If you have broken the outer panels of your DSC-W830, do not worry. This guide will take you through the correct steps of remove both the front and back panels.
Was du brauchst
Remove the six 3.5mm Phillips #000 screws.
Rotate the lock away from the camera.
Remove the two plastic spacers between the front and the back panels.
Carefully remove the back panel.
Fast fertig!
Abschluss
