Einleitung
This will show you how to disassemble the camera and show you how to safely and successfully remove the LCD.
Was du brauchst
Remove the six 3.5mm Phillips #000 screws.
Rotate the lock away from the camera.
Remove the two plastic spacers between the front and the back panels.
Carefully remove the back panel.
Disconnect the no-fuss ribbon cable by gently pulling it out of the button board.
Push the bottom right corner of the LCD screen out and slide it to the right to release it from the clips.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
5 Kommentare
hii
plaz help me
pless need a sony dsc-'''''wx''''' 830 display LED
Sony Cyber-Shot DSC-W830 LCD ……WowObjects LCD Display Screen For SONY DSC-W150 same hai ya different hai
Hi I need a one DSC w810 display how much. ?
How can contact you ?
Sony dsc s2000 model camera need
Display & lens unit
