Zum Hauptinhalt wechseln
Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement
Was du brauchst
  1. Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement, Micro-USB Port: Schritt 1, Bild 1 von 3 Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement, Micro-USB Port: Schritt 1, Bild 2 von 3 Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement, Micro-USB Port: Schritt 1, Bild 3 von 3
    • Remove the battery before beginning.
    • Remove the three screws from the side of the lens using a JIS #000 screwdriver.
    • Remove the longer single screw from the bottom of the lens using a JIS #000 screwdriver.
  2. Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: Schritt 2, Bild 1 von 2 Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: Schritt 2, Bild 2 von 2
    • Remove the housing over the lens circuit board.
    • When removing the housing from over the circuit board, be cautious of static when touching the circuit board as to not fry any necessary components.
  3. Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: Schritt 3, Bild 1 von 1
    • Unplug the micro-USB type B port from the main circuit board in the lens.
    • When handling the flex cable, be careful as to not destroy this delicate part and cause damage to other components.
  4. Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: Schritt 4, Bild 1 von 2 Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: Schritt 4, Bild 2 von 2
    • Set the camera aside.
    • Remove the two JIS #000 screws connecting the micro-USB type B port to the housing frame.
  5. Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: Schritt 5, Bild 1 von 3 Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: Schritt 5, Bild 2 von 3 Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: Schritt 5, Bild 3 von 3
    • Remove the damaged micro-USB type B port by lightly pulling near the cable connector.
    • Remove the micro-USB port from the case and replace it with a new micro-USB type B port.
Abschluss
Juliana Sinobio
121 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 28
Insgesamt: 948
