Zum Hauptinhalt wechseln
Sony Cyber-shot DSC-H20 Flash Assembly Replacement
Was du brauchst
  1. Sony Cyber-shot DSC-H20 Flash Assembly Replacement, Flash Assembly: Schritt 1, Bild 1 von 2 Sony Cyber-shot DSC-H20 Flash Assembly Replacement, Flash Assembly: Schritt 1, Bild 2 von 2
    • Slide open the battery cover and remove the battery and the Memory Stick Duo.
    • Return the battery cover to its closed position.
  2. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: Schritt 2, Bild 1 von 1
    • Remove all three screws from the bottom of the camera.
  3. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: Schritt 3, Bild 1 von 2 Sony Cyber-shot DSC-H20 Flash Assembly Replacement: Schritt 3, Bild 2 von 2
    • Remove the screws on the left and right sides of the camera.
  4. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: Schritt 4, Bild 1 von 3 Sony Cyber-shot DSC-H20 Flash Assembly Replacement: Schritt 4, Bild 2 von 3 Sony Cyber-shot DSC-H20 Flash Assembly Replacement: Schritt 4, Bild 3 von 3
    • Press down on the flash cover to raise the flash.
    • Remove both screws that hold the flash cover to the body of the camera.
  5. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: Schritt 5, Bild 1 von 2 Sony Cyber-shot DSC-H20 Flash Assembly Replacement: Schritt 5, Bild 2 von 2
    • Place the camera upside down with the battery port positioned upward.
    • Slide open the battery port.
  6. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: Schritt 6, Bild 1 von 3 Sony Cyber-shot DSC-H20 Flash Assembly Replacement: Schritt 6, Bild 2 von 3 Sony Cyber-shot DSC-H20 Flash Assembly Replacement: Schritt 6, Bild 3 von 3
    • Pry the front cover of the camera off with the plastic opening tool.
  7. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: Schritt 7, Bild 1 von 1
    • Remove the power shutter unit
  8. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: Schritt 8, Bild 1 von 2 Sony Cyber-shot DSC-H20 Flash Assembly Replacement: Schritt 8, Bild 2 von 2
    • Unscrew the screw located at the back left corner of the flash component.
    • Set the flash component aside.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team 1-1, Leahy Winter 2015 Mitglied von USF Tampa, Team 1-1, Leahy Winter 2015
USFT-LEAHY-W15S1G1
3 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
how to bye power sutter unit
aloke mondal - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 17
Insgesamt: 1,387
