Zum Hauptinhalt wechseln
Sony Cyber-shot DSC-H20 Front Cover Replacement
Was du brauchst
  1. Sony Cyber-shot DSC-H20 Front Cover Replacement, Front Cover: Schritt 1, Bild 1 von 2 Sony Cyber-shot DSC-H20 Front Cover Replacement, Front Cover: Schritt 1, Bild 2 von 2
    • Slide open the battery cover and remove the battery and the Memory Stick Duo.
    • Return the battery cover to its closed position.
  2. Sony Cyber-shot DSC-H20 Front Cover Replacement: Schritt 2, Bild 1 von 1
    • Remove all three screws from the bottom of the camera.
  3. Sony Cyber-shot DSC-H20 Front Cover Replacement: Schritt 3, Bild 1 von 2 Sony Cyber-shot DSC-H20 Front Cover Replacement: Schritt 3, Bild 2 von 2
    • Remove the screws on the left and right sides of the camera.
  4. Sony Cyber-shot DSC-H20 Front Cover Replacement: Schritt 4, Bild 1 von 3 Sony Cyber-shot DSC-H20 Front Cover Replacement: Schritt 4, Bild 2 von 3 Sony Cyber-shot DSC-H20 Front Cover Replacement: Schritt 4, Bild 3 von 3
    • Press down on the flash cover to raise the flash.
    • Remove both screws that hold the flash cover to the body of the camera.
  5. Sony Cyber-shot DSC-H20 Front Cover Replacement: Schritt 5, Bild 1 von 2 Sony Cyber-shot DSC-H20 Front Cover Replacement: Schritt 5, Bild 2 von 2
    • Place the camera upside down with the battery port positioned upward.
    • Slide open the battery port.
  6. Sony Cyber-shot DSC-H20 Front Cover Replacement: Schritt 6, Bild 1 von 3 Sony Cyber-shot DSC-H20 Front Cover Replacement: Schritt 6, Bild 2 von 3 Sony Cyber-shot DSC-H20 Front Cover Replacement: Schritt 6, Bild 3 von 3
    • Pry the front cover of the camera off with the plastic opening tool.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 1-1, Leahy Winter 2015 Mitglied von USF Tampa, Team 1-1, Leahy Winter 2015
USFT-LEAHY-W15S1G1
3 Mitglieder
10 Anleitungen geschrieben
1 Guide Comment
I need a new battery port. It has a broken lid and doesn’t keep it closed. Anyone knows where can I get one?
rubens brakarz - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 23
Insgesamt: 1,053
