Zum Hauptinhalt wechseln
Sony Cyber-shot DSC-H20 Screen Replacement
Was du brauchst
  1. Sony Cyber-shot DSC-H20 Screen Replacement, Screen: Schritt 1, Bild 1 von 2 Sony Cyber-shot DSC-H20 Screen Replacement, Screen: Schritt 1, Bild 2 von 2
    • Slide open the battery cover and remove the battery and the Memory Stick Duo.
    • Return the battery cover to its closed position.
  2. Sony Cyber-shot DSC-H20 Screen Replacement: Schritt 2, Bild 1 von 1
    • Remove all three screws from the bottom of the camera.
  3. Sony Cyber-shot DSC-H20 Screen Replacement: Schritt 3, Bild 1 von 2 Sony Cyber-shot DSC-H20 Screen Replacement: Schritt 3, Bild 2 von 2
    • Remove the screws on the left and right sides of the camera.
  4. Sony Cyber-shot DSC-H20 Screen Replacement: Schritt 4, Bild 1 von 3 Sony Cyber-shot DSC-H20 Screen Replacement: Schritt 4, Bild 2 von 3 Sony Cyber-shot DSC-H20 Screen Replacement: Schritt 4, Bild 3 von 3
    • Press down on the flash cover to raise the flash.
    • Remove both screws that hold the flash cover to the body of the camera.
  5. Sony Cyber-shot DSC-H20 Screen Replacement: Schritt 5, Bild 1 von 1
    • Place the camera upside down with the battery port positioned upward.
    • Slide open the battery port.
  6. Sony Cyber-shot DSC-H20 Screen Replacement: Schritt 6, Bild 1 von 3 Sony Cyber-shot DSC-H20 Screen Replacement: Schritt 6, Bild 2 von 3 Sony Cyber-shot DSC-H20 Screen Replacement: Schritt 6, Bild 3 von 3
    • Pry the front cover of the camera off with the plastic opening tool.
  7. Sony Cyber-shot DSC-H20 Screen Replacement: Schritt 7, Bild 1 von 1
    • Remove the power shutter unit.
  8. Sony Cyber-shot DSC-H20 Screen Replacement: Schritt 8, Bild 1 von 2 Sony Cyber-shot DSC-H20 Screen Replacement: Schritt 8, Bild 2 von 2
    • Unscrew the screw located at the back left corner of the flash component.
    • Set the flash component aside.
  9. Sony Cyber-shot DSC-H20 Screen Replacement: Schritt 9, Bild 1 von 1
    • Remove the two screws from the bottom of the motherboard.
  10. Sony Cyber-shot DSC-H20 Screen Replacement: Schritt 10, Bild 1 von 1
    • Use the plastic opening tool to assist you in separating the metal frame from the back cover of the camera.
  11. Sony Cyber-shot DSC-H20 Screen Replacement: Schritt 11, Bild 1 von 2 Sony Cyber-shot DSC-H20 Screen Replacement: Schritt 11, Bild 2 von 2
    • Flip the metal frame over to the left side of the camera and onto the surface on which you are working.
  12. Sony Cyber-shot DSC-H20 Screen Replacement: Schritt 12, Bild 1 von 2 Sony Cyber-shot DSC-H20 Screen Replacement: Schritt 12, Bild 2 von 2
    • Now remove the LCD screen by bringing the back cover over to the left so that the LCD screen falls into your hand.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Rachel Payne
386 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 1-1, Leahy Winter 2015 Mitglied von USF Tampa, Team 1-1, Leahy Winter 2015
USFT-LEAHY-W15S1G1
3 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
Thank you so much. I could successfully open the camera and got the LCD display out. But I couldn't find out how to replace the LCD, I wanted to mean where to open the LCD cable?
ummejamil - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 17
Insgesamt: 1,954
