Was du brauchst
Slide open the battery cover and remove the battery and the Memory Stick Duo.
Return the battery cover to its closed position.
Press down on the flash cover to raise the flash.
Remove both screws that hold the flash cover to the body of the camera.
Place the camera upside down with the battery port positioned upward.
Slide open the battery port.
Unscrew the screw located at the back left corner of the flash component.
Set the flash component aside.
Use the plastic opening tool to assist you in separating the metal frame from the back cover of the camera.
Flip the metal frame over to the left side of the camera and onto the surface on which you are working.
Now remove the LCD screen by bringing the back cover over to the left so that the LCD screen falls into your hand.
2 weitere Personen haben diese Anleitung absolviert.
