Einleitung
The tripod port may be loose, broken or faulty. In any case, replacement of the tripod port involves first removing the LCD Screen and the Motherboard. Please refer to the LCD Screen prerequisite guide and the Motherboard prerequisite guide for proper removal of the LCD Screen and the Motherboard.
Was du brauchst
Using a screwdriver, remove the five 6mm screws located on the back panel.
Using a screwdriver, remove the two 3mm screws located on the back panel.
Using a screwdriver, remove one 6mm screw on the front panel.
Using a screwdriver, remove two 3mm screws on the front panel.
Open the SD Door, unscrew and remove the single 6mm screw closest to "PUSH IN/OUT" under the SD card slot.
Using a screwdriver, remove the three 4mm screws that attach the LCD to the camera motherboard. (The LCD is contained in a holding plate, attached to the motherboard with a ribbon cable.)
Using a screwdriver, remove the single 4mm screw at the bottom of the holding plate.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Using tweezers, open the LCD ribbon port by lifting the black hinge. (The LCD ribbon cable will detach.)
Disconnect the four amber-colored ribbon cables from the motherboard using tweezers.
Using a screwdriver, remove the four 4mm screws from the motherboard.
Then remove the single 4mm screw connecting the motherboard to the main body of the camera.
Using tweezers, lift the tripod port up and away from the camera body
