Einleitung
This guide shows a step by step process on how to replace the rear case of the camera. You must be careful during this guide due to certain parts being very vulnerable to breaking. If the case isn't staying in position or the buttons are unresponsive take a look at our troubleshooting guide for more help.
Was du brauchst
Remove the five 6mm Phillips #000 screws.
Remove the four 3mm Phillips #000 screws.
Use the flat end of a plastic spudger to pry apart the rear cover from the body of the camera.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
