Zum Hauptinhalt wechseln
Sony Cyber-shot DSC-HX1 LCD Screen Replacement
Was du brauchst
  1. Sony Cyber-shot DSC-HX1 LCD Screen Replacement, LCD Screen: Schritt 1, Bild 1 von 1
    • Extend the LCD screen away from the camera to access the screws on the back of its housing.
  2. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: Schritt 2, Bild 1 von 1
    • Unscrew the three #00 2.0 mm Phillips screws on the back of the casing.
  3. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: Schritt 3, Bild 1 von 1
    • Place the camera with the lens down.
    • Tilt the screen upwards to see the screw on the bottom of the housing.
    • Unscrew this #00 4.0 mm Phillips screw.
  4. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: Schritt 4, Bild 1 von 1
    • Pry the casing apart using your plastic opening tool. Begin by prying at the hole where you removed the screw and continue along the seam.
  5. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: Schritt 5, Bild 1 von 2 Sony Cyber-shot DSC-HX1 LCD Screen Replacement: Schritt 5, Bild 2 von 2
    • Lift the transparent section of the plastic housing off.
    • Lift the rubber screen bumper off of the screen.
  6. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: Schritt 6, Bild 1 von 1
    • Pull up on the screen to reveal the data attachment cable.
    • Carefully pull the LCD screen away from enclosure to remove the cable and screen completely.
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 17-3, Forte Spring 2015 Mitglied von Cal Poly, Team 17-3, Forte Spring 2015
CPSU-FORTE-S15S17G3
4 Mitglieder
10 Anleitungen geschrieben
5 Kommentare
What is the lcd screen part number? And where can i find it online? I need to replace my dads cracked screen.
sportyvangchick - Antwort
lao90227ay
s300gc05lb9e21xmo usp5280371
lajos rohony - Antwort
Display my order
prince Choudhary - Antwort
Screen LCDOnline booking
qual tela de lcd posso usar?
não achei
Thayane Laurencio - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 49
Insgesamt: 3,513
