Zum Hauptinhalt wechseln
Sony Cyber-shot DSC-HX1 Lens Assembly Replacement
Was du brauchst
  1. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure the surface you place the screen on is clean of debris and dust. Otherwise you risk scratching your screen.
    • Place the camera with the bottom facing you and the lens facing up.
  2. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: Schritt 2, Bild 1 von 1
    • Push down and away from the camera to the left on the indicated indentation in the battery cover. The compartment should slide open as shown.
  3. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: Schritt 3, Bild 1 von 2 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: Schritt 3, Bild 2 von 2
    • Push the blue tab towards the camera body to the right, while simultaneously pulling out the battery.
    • The battery is not shown here. However, normally the battery would be in the displayed compartment.
  4. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement, Motherboard: Schritt 4, Bild 1 von 2 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement, Motherboard: Schritt 4, Bild 2 von 2
    • Close the battery cover by pushing the cover inwards and sliding it to the left to allow more maneuverability when disassembling other parts of the camera.
  5. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: Schritt 5, Bild 1 von 1
    • Unscrew the four #00 4.0 mm Phillips screws on the bottom of the camera.
  6. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: Schritt 6, Bild 1 von 1
    • Remove the two #00 4.0 mm Phillips screws shown on the side of the camera.
  7. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: Schritt 7, Bild 1 von 1
    • Unscrew the #00 4.0 mm Phillips screw on the top next to the view finder.
  8. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: Schritt 8, Bild 1 von 1
    • Pull open the plastic port covers on the side of the camera.
    • Remove the revealed #00 4.0 mm Phillips screw.
  9. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: Schritt 9, Bild 1 von 3 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: Schritt 9, Bild 2 von 3 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: Schritt 9, Bild 3 von 3
    • Lift the back LCD screen to reveal the back of the camera unit.
    • Unscrew the three #00 4.0 mm Phillips screws at the edge and center of the back camera unit.
  10. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: Schritt 10, Bild 1 von 3 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: Schritt 10, Bild 2 von 3 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: Schritt 10, Bild 3 von 3
    • Using the plastic opening tool, pry apart the bottom of the camera at the line between the four removed screws.
    • Place the camera on its lens and use the plastic opening tool to pry at the crack in the case on all four sides of the camera.
    • Apply moderate force to the backside of the camera enclosure until the two pieces separate.
  11. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: Schritt 11, Bild 1 von 2 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: Schritt 11, Bild 2 von 2
    • Remove the #00 4.0 mm Phillips screw and the #00 6.0 mm Phillips screw holding the motherboard to the front enclosure.
    • Disconnect the eight ribbon cables from their ports on the motherboard.
  12. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: Schritt 12, Bild 1 von 2 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: Schritt 12, Bild 2 von 2
    • Detach the metal bracket from the enclosure by removing the two #00 4.0 mm Phillips screws.
  13. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: Schritt 13, Bild 1 von 2 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: Schritt 13, Bild 2 von 2
    • If you feel resistance from the board, double check all screws and cables have been removed to avoid damage.
    • Completely remove the motherboard by gently pulling the board away from the camera.
  14. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement, Lens Assembly: Schritt 14, Bild 1 von 1
    • Unscrew the #00 6.0 mm Phillips screw on the left side of the lens.
  15. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: Schritt 15, Bild 1 von 2 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: Schritt 15, Bild 2 von 2
    • The lens assembly contains exposed leads to capacitors. Be very careful to avoid contact or discharge capacitors before handling as touching the capacitors could lead to electric shock.
    • Gently slide the lens assembly out of the front camera housing and remove completely.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 17-3, Forte Spring 2015 Mitglied von Cal Poly, Team 17-3, Forte Spring 2015
CPSU-FORTE-S15S17G3
4 Mitglieder
10 Anleitungen geschrieben
2 Kommentare
Hi!
Very good tutorial, thanks a lot.
I have a question : after reassembling the device, do you need to do some kind of adjustment or is it "simply plug-and-play"?
Best regards,
Marin
Marin Aymon - Antwort
Muy bueno el tutorial felicitaciones, sin embargo faltaron tornillos por nombrar, saludos
Cesar Carrillo - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 16
Letzte 30 Tage: 45
Insgesamt: 5,188
