Zum Hauptinhalt wechseln
Sony Cyber-shot DSC-HX100V Viewfinder Replacement
Was du brauchst
  1. Sony Cyber-shot DSC-HX100V Viewfinder Replacement, Viewfinder: Schritt 1, Bild 1 von 1
    • Make sure camera is turned off.
    • Press the ON/Off button to turn off the camera.
    • WARNING: Data may be lost if the camera remains on.
  2. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: Schritt 2, Bild 1 von 3 Sony Cyber-shot DSC-HX100V Viewfinder Replacement: Schritt 2, Bild 2 von 3 Sony Cyber-shot DSC-HX100V Viewfinder Replacement: Schritt 2, Bild 3 von 3
    • Use the Phillips screwdriver size #00 to remove the 1.59mm #00 screws.
    • Remove 2 screws from the side of the camera.
    • Remove 4 screws on the bottom of the camera.
    • Remove 1 screw next to the eyepiece.
  3. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: Schritt 3, Bild 1 von 1
    • Flip the screen back to reveal 2 hidden screws.
    • Remove the two 1.59mm #00 screws on the left with the Phillips #00 screwdriver.
  4. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: Schritt 4, Bild 1 von 1
    • Pull the back panel of the camera upward.
    • Use a spudger to help pry open the back panel.
  5. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: Schritt 5, Bild 1 von 1
    • Open the back panel to view the inside of the camera.
    • If the orange ribbon cable disconnects from its designated port, do not panic. The cable is easy to reinsert.
  6. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: Schritt 6, Bild 1 von 3 Sony Cyber-shot DSC-HX100V Viewfinder Replacement: Schritt 6, Bild 2 von 3 Sony Cyber-shot DSC-HX100V Viewfinder Replacement: Schritt 6, Bild 3 von 3
    • Carefully pull out the the eyepiece.
    • Detach the orange ribbon cable that connects it to the green panel by carefully pulling outwards.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
DaQuawn
254 Reputation
2 Anleitungen geschrieben
Sam Houston State, Team 11-3, Blackburne Winter 2015 Mitglied von Sam Houston State, Team 11-3, Blackburne Winter 2015
SHSU-BLACKBURNE-W15S11G3
3 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
Thank you very much for the importent articles made for us. If I can please put , how to replace the flasher as well.
Satsara Gunaratne - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 922
