Einleitung
If your computer does not register that the Sony Cyber-shot DSC-HX300 is plugged in then the HDMI/USB ports may need to be replaced.
Was du brauchst
Turn the camera upside down. This is a view of the bottom of the camera.
Remove the 3 (4 cm) Phillips head screws located on the back of the camera.
Remove the 2 (4 cm) Phillips head screws on the right side of the camera.
Turn the camera upside down to remove the remaining the 3 (4 cm) Phillips head screws holding the plastic camera housing together.
Carefully remove the 7 ribbon wires connected to the mother board.
Remove the 2 (5 cm) Phillips head screws on the speaker mounting bracket.
Remove the 3 (4 cm) Phillips head screws that secure the motherboard to the camera.
Lift up on the speaker mounting bracket to remove it.
Carefully disconnect the ribbon wire connecting the HDMI port to the Motherboard.
Once the Motherboard is removed the replacement can be installed.
Remove the 3 (4 cm) Phillips head screws securing a mounting bracket over the HDMI/USB Port.
2 weitere Personen haben diese Anleitung absolviert.
