Einleitung
If the Sony Cyber-shot DSC-HX300 is failing to power, while it has a full battery and the LCD screen works, then it is possible that the motherboard has gone out and needs to be replaced.
Was du brauchst
Turn the camera upside down. This is a view of the bottom of the camera.
Remove the 3 (4 cm) Phillips head screws located on the back of the camera.
Remove the 2 (4 cm) Phillips head screws on the right side of the camera.
Turn the camera upside down to remove the remaining the 3 (4 cm) Phillips head screws holding the plastic camera housing together.
Carefully remove the 7 ribbon wires connected to the mother board.
Remove the 2 (5 cm) Phillips head screws on the speaker mounting bracket.
Remove the 3 (4 cm) Phillips head screws that secure the motherboard to the camera.
Lift up on the speaker mounting bracket to remove it.
Carefully disconnect the ribbon wire connecting the HDMI port to the Motherboard.
Once the Motherboard is removed the replacement can be installed.
3 Kommentare
During my vacation two capicators on the motherboard failed and 'exploded'.
I've ordered the motherboard and replaced it exactly as described here. Thanks for the explanation!
But since I've replaced it, I have autofocus problems, the camera isn't capable to focus, especially in wide zoom.
Is this something that needs to be calibrated or something?
That ist what i need to know too. Where can i order a Motherboard?
