Einleitung
Is the View Finder not working even after the LCD/Finder button has been pressed? Then the View Finder may need replacing.
Was du brauchst
Turn the camera upside down. This is a view of the bottom of the camera.
Remove the 3 (4 cm) Philips head screws holding the plastic camera housing together. They are located on the back of the camera.
Remove the 2 (4 cm) Phillips head screws on the right side of the camera.
Turn the camera upside down and remove the remaining 3 (4 cm) Phillips head screws holding the plastic housing together.
Remove the 1 (2 cm) Phillips head screw
Remove the 2 (5 cm) Phillips head screws that mount the View Finder to the camera.
Carefully disconnect the ribbon wire that connects the View Finder to the Motherboard.
Eine weitere Person hat diese Anleitung absolviert.
