Einleitung
A failed battery is perhaps the most common problem encountered with a modern point and shoot camera. This guide provides detailed steps for the replacement of a battery in a Sony DSC-HX80
Was du brauchst
Before disassembling any part of the camera, turn off power by pressing down on the ON/OFF button. The ON/OFF button is located on top of the camera.
Open compartment located at the bottom of the camera. Slide the LOCK/OPEN switch to the OPEN side.
Locate the small blue tab on the side. Pull it in direction away from battery. Remove battery and set aside.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
