Einleitung
This guide will show you the steps to removing and replacing the motherboard of the camera.
Was du brauchst
Place the device so bottom of the camera is facing up .
Remove the five black M1.4 X 3.5 Phillips head screws with a Phillips #000 screwdriver.
Remove the marked black M1.4 X 3.5 Phillips head screws on the side of the camera with a Phillips #000 screwdriver.
Disconnect the control board data cable by wiggling carefully with your fingertips. Set the control board to the side once it is disconnected.
Use the plastic opening tool with a prying motion to remove the side cover of the camera.
Orient the device so the lens is facing down.
Remove the two black M1.4 X 3.5 Phillips head screws using Phillips #000 screwdriver.
Remove the black M1.4 X 3.5 Phillips head screw.
Remove the ribbon cable connecting LCD display to camera sensor and battery housing.
Make sure all ribbon cables are unplugged and remove the motherboard.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
2 Kommentare
super Anleitung, trotz aller Vorsicht ist ein Flachbandkabel kaputt gegangen, und zwar das 2 adrige zu Sucher. Wie kann man Flachbandkabel reparieren oder ersetzen?
LG
Michael
Hello!
Nice help to open the camera for fixing viewfinder problems: when not switching on, even when FINDER/MONITOR mode on FINDER, there might be a bad contact in the visor connector. It is a snap lock micro connector, open the lock, then carefully remove clean and replace ribbon cable:this may clear the trouble.
But attention: At least on HX9O without V ext. there are some more screws ;-) and niceties
- one in step 3, under the MULTI connector cap
- 3 on different places to remove LCD screen
Also, there is also an antenna , connected to the LCD assembly and lightly glued on the side
