Zum Hauptinhalt wechseln
Sony Cyber-shot DSC-P100 Camera Flash Replacement
Was du brauchst
  1. Sony Cyber-shot DSC-P100 Camera Flash Replacement, Front Casing: Schritt 1, Bild 1 von 3 Sony Cyber-shot DSC-P100 Camera Flash Replacement, Front Casing: Schritt 1, Bild 2 von 3 Sony Cyber-shot DSC-P100 Camera Flash Replacement, Front Casing: Schritt 1, Bild 3 von 3
    • First locate the appropriate screws for detachment.
  2. Sony Cyber-shot DSC-P100 Camera Flash Replacement: Schritt 2, Bild 1 von 1
    • Remove the five screws shown using a Phillips #00 Screwdriver.
    • It is important to put the small screws in a safe location in order to reassemble the casing.
  3. Sony Cyber-shot DSC-P100 Camera Flash Replacement: Schritt 3, Bild 1 von 1
    • Using a spudger, carefully pry open the front casing.
  4. Sony Cyber-shot DSC-P100 Camera Flash Replacement: Schritt 4, Bild 1 von 2 Sony Cyber-shot DSC-P100 Camera Flash Replacement: Schritt 4, Bild 2 von 2
    • Carefully separate the front casing from the camera body.
    • CAUTION: Be careful not to break the wire connecting the front casing and the camera.
  5. Sony Cyber-shot DSC-P100 Camera Flash Replacement, Camera Flash: Schritt 5, Bild 1 von 2 Sony Cyber-shot DSC-P100 Camera Flash Replacement, Camera Flash: Schritt 5, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Using tweezers, gently pull the ribbon trace out of its housing found on the left side of the flash.
  6. Sony Cyber-shot DSC-P100 Camera Flash Replacement: Schritt 6, Bild 1 von 3 Sony Cyber-shot DSC-P100 Camera Flash Replacement: Schritt 6, Bild 2 von 3 Sony Cyber-shot DSC-P100 Camera Flash Replacement: Schritt 6, Bild 3 von 3
    • Using a spudger, pry the small latch between the lens and the flash open to release the flash.
    • Pull the flash away from the camera.
Abschluss
Katie McCraw
191 Reputation
7 Anleitungen geschrieben
Clemson, Team 1-5, Benson Spring 2012 Mitglied von Clemson, Team 1-5, Benson Spring 2012
CLEM-BENSON-S12S1G5
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 23
Insgesamt: 2,714
