Zum Hauptinhalt wechseln
Sony Cyber-shot DSC-P100 Camera Lens Replacement
Was du brauchst
  1. Sony Cyber-shot DSC-P100 Camera Lens Replacement, Front Casing: Schritt 1, Bild 1 von 3 Sony Cyber-shot DSC-P100 Camera Lens Replacement, Front Casing: Schritt 1, Bild 2 von 3 Sony Cyber-shot DSC-P100 Camera Lens Replacement, Front Casing: Schritt 1, Bild 3 von 3
    • First locate the appropriate screws for detachment.
  2. Sony Cyber-shot DSC-P100 Camera Lens Replacement: Schritt 2, Bild 1 von 1
    • Remove the five screws shown using a Phillips #00 Screwdriver.
    • It is important to put the small screws in a safe location in order to reassemble the casing.
  3. Sony Cyber-shot DSC-P100 Camera Lens Replacement: Schritt 3, Bild 1 von 1
    • Using a spudger, carefully pry open the front casing.
  4. Sony Cyber-shot DSC-P100 Camera Lens Replacement: Schritt 4, Bild 1 von 2 Sony Cyber-shot DSC-P100 Camera Lens Replacement: Schritt 4, Bild 2 von 2
    • Carefully separate the front casing from the camera body.
    • CAUTION: Be careful not to break the wire connecting the front casing and the camera.
  5. Sony Cyber-shot DSC-P100 Camera Lens Replacement, Back Casing: Schritt 5, Bild 1 von 3 Sony Cyber-shot DSC-P100 Camera Lens Replacement, Back Casing: Schritt 5, Bild 2 von 3 Sony Cyber-shot DSC-P100 Camera Lens Replacement, Back Casing: Schritt 5, Bild 3 von 3
    • Remove the four screws from the casing.
  6. Sony Cyber-shot DSC-P100 Camera Lens Replacement: Schritt 6, Bild 1 von 2 Sony Cyber-shot DSC-P100 Camera Lens Replacement: Schritt 6, Bild 2 von 2
    • Carefully pull the back casing away from the camera.
  7. Sony Cyber-shot DSC-P100 Camera Lens Replacement, Camera Lens: Schritt 7, Bild 1 von 2 Sony Cyber-shot DSC-P100 Camera Lens Replacement, Camera Lens: Schritt 7, Bild 2 von 2
    • Remove the two screws on the back side of the camera surrounding the LCD screen.
  8. Sony Cyber-shot DSC-P100 Camera Lens Replacement: Schritt 8, Bild 1 von 3 Sony Cyber-shot DSC-P100 Camera Lens Replacement: Schritt 8, Bild 2 von 3 Sony Cyber-shot DSC-P100 Camera Lens Replacement: Schritt 8, Bild 3 von 3
    • Remove the two ribbon traces found on the left side of the lens on the front of camera holding the lens in place.
    • Carefully pull the lens away front the camera until it is released.
  9. Sony Cyber-shot DSC-P100 Camera Lens Replacement: Schritt 9, Bild 1 von 1
    • The lens is now successfully removed from the camera.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Katie McCraw
191 Reputation
7 Anleitungen geschrieben
Clemson, Team 1-5, Benson Spring 2012 Mitglied von Clemson, Team 1-5, Benson Spring 2012
CLEM-BENSON-S12S1G5
4 Mitglieder
14 Anleitungen geschrieben
Ein Kommentar
Is there a way to disassemble the lens to correct the alignment. My daughter dropped it and I think the mechanism has been misaligned.
Macjune Tolentino - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 12
Insgesamt: 2,791
