Einleitung
The camera will need to be completely disassembled to get to the flash, so only do this as as a last resort.
Was du brauchst
Open the battery compartment and remove the batteries.
Remove all of the visible screws on the outside of the case.
Open the memory card compartment.
Remove the screw next to the memory card slot.
Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
Remove all six screws on the front side of the motherboard circled in the picture.
Pull the motherboard from the rest of the housing.
Discharge the yellow capacitor attached to the flash unit by shorting the leads with a screw driver.
