Einleitung
The LCD should be checked if the screen is blank or broken.
  1. Open the battery compartment and remove the batteries.
    • Open the battery compartment and remove the batteries.
    • Remove all of the visible screws on the outside of the case.
    • There should be three of them that are all easily located.
  2. Open the memory card compartment.
    • Open the memory card compartment.
    • Remove the screw next to the memory card slot.
  3. Pull apart the front and back cover pieces carefully.
    • Pull apart the front and back cover pieces carefully.
    • The front cover should come completely free with little effort.
    • The back cover will still be attached to the circuit board.
  4. Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
    • Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
    • The circuitry will still be connected to the back case by ribbon cables.
  5. Open the case as shown.
    • Open the case as shown.
  6. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  7. Unclip the clip holding the ribbon cable in.
    • Unclip the clip holding the ribbon cable in.
    • Other ribbon cables might not have a clips.
  8. Pull the ribbon cable out.
    • Pull the ribbon cable out.
  9. Unclip the ribbon cable shown the in picture.
    • Unclip the ribbon cable shown the in picture.
    • Some ribbon cables do not have a clip holding them in.
  10. Pull the ribbon cable out.
  11. Remove 7 Screws to remove plate and expose LCD screen.
    • Remove 7 Screws to remove plate and expose LCD screen.
  12. Remove LCD plate to expose LCD components and ribbon cables
    • Remove LCD plate to expose LCD components and ribbon cables
  13. Check connection of LCD to cables
    • Check connection of LCD to cables
    • If cables are intact, disconnect cables and replace LCD with new part
  14. Repeat steps in reverse order to reassemble the camera
    • Repeat steps in reverse order to reassemble the camera
Abschluss
Mark
13 Reputation
1 Anleitung geschrieben
Cal Poly, Team 3-43, Regan Winter 2011 Mitglied von Cal Poly, Team 3-43, Regan Winter 2011
CPSU-REGAN-W11S3G43
4 Mitglieder
10 Anleitungen geschrieben
I don’t know the cause of my camera not turning on.
Smgmc64 Productions - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 2,284
