Einleitung
The LCD should be checked if the screen is blank or broken.
Was du brauchst
Open the battery compartment and remove the batteries.
Remove all of the visible screws on the outside of the case.
Open the memory card compartment.
Remove the screw next to the memory card slot.
Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
Unclip the ribbon cable shown the in picture.
Check connection of LCD to cables
If cables are intact, disconnect cables and replace LCD with new part
