Einleitung
If you are confident that your motherboard needs to be replaced, and have a replacement motherboard, then follow this guide.
Was du brauchst
Open the battery compartment and remove the batteries.
Remove all of the visible screws on the outside of the case.
Open the memory card compartment.
Remove the screw next to the memory card slot.
Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
Remove all six screws on the front side of the motherboard circled in the picture.
Pull the motherboard from the rest of the housing.
The motherboard is now free, and ready to be replaced by a new one.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
