Zum Hauptinhalt wechseln
Sony Cyber-shot DSC-P52 Motherboard Replacement
Was du brauchst
  1. Sony Cyber-shot DSC-P52 Motherboard Replacement, Outer Case: Schritt 1, Bild 1 von 1
    • Open the battery compartment and remove the batteries.
    • Remove all of the visible screws on the outside of the case.
    • There should be three of them that are all easily located.
  2. Sony Cyber-shot DSC-P52 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Open the memory card compartment.
    • Remove the screw next to the memory card slot.
  3. Sony Cyber-shot DSC-P52 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Pull apart the front and back cover pieces carefully.
    • The front cover should come completely free with little effort.
    • The back cover will still be attached to the circuit board.
  4. Sony Cyber-shot DSC-P52 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
    • The circuitry will still be connected to the back case by ribbon cables.
  5. Sony Cyber-shot DSC-P52 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Open the case as shown.
  6. Sony Cyber-shot DSC-P52 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Unclip the clip holding the ribbon cable in.
    • Other ribbon cables might not have a clips.
  7. Sony Cyber-shot DSC-P52 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Pull the ribbon cable out.
  8. Sony Cyber-shot DSC-P52 Motherboard Replacement, Motherboard Assembly: Schritt 8, Bild 1 von 1
    • Remove all six screws on the front side of the motherboard circled in the picture.
    • Pull the motherboard from the rest of the housing.
    • It will still be connected to the flash unit.
  9. Sony Cyber-shot DSC-P52 Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Remove the cable on the back side of the motherboard.
  10. Sony Cyber-shot DSC-P52 Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Detach the ribbon cables shown.
    • Careful! Touching the leads of the large yellow capacitor can result in a painful shock.
    • Remove the flash unit from the motherboard.
  11. Sony Cyber-shot DSC-P52 Motherboard Replacement, Motherboard: Schritt 11, Bild 1 von 1
    • The motherboard is now free, and ready to be replaced by a new one.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Trevor
295 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 3-43, Regan Winter 2011 Mitglied von Cal Poly, Team 3-43, Regan Winter 2011
CPSU-REGAN-W11S3G43
4 Mitglieder
20 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 20
Insgesamt: 1,175
