Zum Hauptinhalt wechseln
Einleitung
This guide explains how to replace the viewfinder in the Sony Cybershot DSC-P52
  1. Open the battery compartment and remove the batteries.
    • Open the battery compartment and remove the batteries.
    • Remove all of the visible screws on the outside of the case.
    • There should be three of them that are all easily located.
  2. Open the memory card compartment.
    • Open the memory card compartment.
    • Remove the screw next to the memory card slot.
  3. Pull apart the front and back cover pieces carefully.
    • Pull apart the front and back cover pieces carefully.
    • The front cover should come completely free with little effort.
    • The back cover will still be attached to the circuit board.
  4. Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
    • Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
    • The circuitry will still be connected to the back case by ribbon cables.
  5. Open the case as shown.
    • Open the case as shown.
  6. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  7. Unclip the clip holding the ribbon cable in.
    • Unclip the clip holding the ribbon cable in.
    • Other ribbon cables might not have a clips.
  8. Pull the ribbon cable out.
    • Pull the ribbon cable out.
  9. Remove the two additional screws on the back of the lens.
    • Remove the two additional screws on the back of the lens.
  10. Detach the ribbon cables and unplug the cable leading to the back of the motherboard.
    • Detach the ribbon cables and unplug the cable leading to the back of the motherboard.
  11. Remove the motherboard and the flash from the rest of the hardware.
    • Remove the motherboard and the flash from the rest of the hardware.
  12. Remove the screw indicated in the picture to detach the lens and the  viewfinder from the other hardware.
    • Remove the screw indicated in the picture to detach the lens and the viewfinder from the other hardware.
  13. Remove the three screws shown to separate the lens from the viewfinder.
    • Remove the three screws shown to separate the lens from the viewfinder.
  14. Purchase a new viewfinder.
    • Purchase a new viewfinder.
    • Repeat the previous steps in reverse order to rebuild.
Abschluss
Kari Johnson
127 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 3-43, Regan Winter 2011 Mitglied von Cal Poly, Team 3-43, Regan Winter 2011
CPSU-REGAN-W11S3G43
4 Mitglieder
10 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 2,016
