Zum Hauptinhalt wechseln
Sony Cyber-shot DSC-P9 LCD Replacement
Was du brauchst
  1. Sony Cyber-shot DSC-P9 LCD Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide the battery latch down the side of the camera with your hands.
    • The latch will automatically pop open.
  2. Sony Cyber-shot DSC-P9 LCD Replacement: Schritt 2, Bild 1 von 1
    • Unlatch the clip over the battery.
    • The battery will partially pop out.
  3. Sony Cyber-shot DSC-P9 LCD Replacement: Schritt 3, Bild 1 von 2 Sony Cyber-shot DSC-P9 LCD Replacement: Schritt 3, Bild 2 von 2
    • Remove the battery from the camera.
  4. Sony Cyber-shot DSC-P9 LCD Replacement, LCD: Schritt 4, Bild 1 von 1
    • Unscrew the four 3.0mm Phillips #000 screws holding the back case onto the camera; there are two screws on top and two on the bottom.
  5. Sony Cyber-shot DSC-P9 LCD Replacement: Schritt 5, Bild 1 von 2 Sony Cyber-shot DSC-P9 LCD Replacement: Schritt 5, Bild 2 von 2
    • Pull the back case gently away from the rest of the camera.
  6. Sony Cyber-shot DSC-P9 LCD Replacement: Schritt 6, Bild 1 von 1
    • Remove the two 3.0mm Phillips #000 screws holding the display to the metal backing.
  7. Sony Cyber-shot DSC-P9 LCD Replacement: Schritt 7, Bild 1 von 2 Sony Cyber-shot DSC-P9 LCD Replacement: Schritt 7, Bild 2 von 2
    • Unlatch the display by sliding it towards the circuit board.
  8. Sony Cyber-shot DSC-P9 LCD Replacement: Schritt 8, Bild 1 von 1
    • Remove the two ribbon cables attached to the circuit board by gently pulling them out of their slots.
    • Be careful not to rip the ribbon cables while disconnecting them.
  9. Sony Cyber-shot DSC-P9 LCD Replacement: Schritt 9, Bild 1 von 1
    • The LCD is now separated from the camera.
Abschluss
Cal Poly, Team 17-25, Amido Spring 2012 Mitglied von Cal Poly, Team 17-25, Amido Spring 2012
CPSU-AMIDO-S12S17G25
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 886
