Was du brauchst
Slide the battery latch down the side of the camera with your hands.
The latch will automatically pop open.
Unscrew the four 3.0mm Phillips #000 screws holding the back case onto the camera; there are two screws on top and two on the bottom.
Remove the two 3.0mm Phillips #000 screws holding the display to the metal backing.
Remove the two ribbon cables attached to the circuit board by gently pulling them out of their slots.
