Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Ersatzteile
Keine Ersatzteile angegeben.
  1. Slide the battery latch down the side of the camera with your hands.
    • Slide the battery latch down the side of the camera with your hands.
    • The latch will automatically pop open.
  2. Unlatch the clip over the battery.
    • Unlatch the clip over the battery.
    • The battery will partially pop out.
  3. Remove the battery from the camera. Remove the battery from the camera.
    • Remove the battery from the camera.
  4. SPAR DIR DAS UPGRADE
    Mach dein iPhone so gut wie neu mit unseren Fix Kits.
    Jetzt entdecken
    Jetzt entdecken
  5. Remove the four 3.0mm Phillips #000 screws on the top of the camera with the phillips screwdriver. Remove the additional four 3.0mm Phillips #000 screws on the bottom of the camera.
    • Remove the four 3.0mm Phillips #000 screws on the top of the camera with the phillips screwdriver.
    • Remove the additional four 3.0mm Phillips #000 screws on the bottom of the camera.
  6. Once the screws are removed, slowly remove the back casing from the rest of the camera. Once the screws are removed, slowly remove the back casing from the rest of the camera.
    • Once the screws are removed, slowly remove the back casing from the rest of the camera.
  7. Then, pull the front case away from the rest of the camera. Then, pull the front case away from the rest of the camera.
    • Then, pull the front case away from the rest of the camera.
  8. After the casing is removed, the camera should look as shown.
    • After the casing is removed, the camera should look as shown.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Jenna Crawford
29 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 17-25, Amido Spring 2012 Mitglied von Cal Poly, Team 17-25, Amido Spring 2012
CPSU-AMIDO-S12S17G25
4 Mitglieder
7 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 689
