Zum Hauptinhalt wechseln
Sony Cyber-shot DSC-S2100 LCD Replacement
Was du brauchst
  1. Sony Cyber-shot DSC-S2100 LCD Replacement, LCD: Schritt 1, Bild 1 von 3 Sony Cyber-shot DSC-S2100 LCD Replacement, LCD: Schritt 1, Bild 2 von 3 Sony Cyber-shot DSC-S2100 LCD Replacement, LCD: Schritt 1, Bild 3 von 3
    • The broken LCD is immediately visible when the camera is turned on.
    • Remove the batteries and, if so equipped, the memory card.
    • Remove the three Philips screws from the bottom of the camera with a Phillips #00 Screwdriver.
  2. Sony Cyber-shot DSC-S2100 LCD Replacement: Schritt 2, Bild 1 von 3 Sony Cyber-shot DSC-S2100 LCD Replacement: Schritt 2, Bild 2 von 3 Sony Cyber-shot DSC-S2100 LCD Replacement: Schritt 2, Bild 3 von 3
    • Remove the two Philips screws from the right side of the camera.
    • Remove the two Philips screws from the left side of the camera.
    • Split the housing by either using a plastic opening tool, or your finger nails. No excessive force is necessary. For ease of accomplishment, start at the battery compartment.
  3. Sony Cyber-shot DSC-S2100 LCD Replacement: Schritt 3, Bild 1 von 3 Sony Cyber-shot DSC-S2100 LCD Replacement: Schritt 3, Bild 2 von 3 Sony Cyber-shot DSC-S2100 LCD Replacement: Schritt 3, Bild 3 von 3
    • Once the rear case has been removed, the LCD and frame are easily identified.
    • Fold the LCD to the right, away from the frame.
    • Do not try to remove the LCD yet since the ribbon cable is still connected.
    • Remove the three Philips screws from the LCD frame.
  4. Sony Cyber-shot DSC-S2100 LCD Replacement: Schritt 4, Bild 1 von 3 Sony Cyber-shot DSC-S2100 LCD Replacement: Schritt 4, Bild 2 von 3 Sony Cyber-shot DSC-S2100 LCD Replacement: Schritt 4, Bild 3 von 3
    • When the LCD frame is removed, the ribbon cable becomes clearly visible.
    • Flip the LCD to its left side. Open the clip of the connector by moving the black lock to the right.
    • Remove the LCD
  5. Sony Cyber-shot DSC-S2100 LCD Replacement: Schritt 5, Bild 1 von 1
    • Ensure the screen displayed greets you, once you reassembled your camera
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
oldturkey03
782.052 Reputation
119 Anleitungen geschrieben
Global Fixers Mitglied von Global Fixers
Community
33 Mitglieder
536 Anleitungen geschrieben
2 Kommentare
你在哪里?把相机给你帮我挨可以吗
Jeanne - Antwort
请问你是在多伦多附近吗?
Jeanne - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 40
Insgesamt: 2,457
