Einleitung
This guide will aid you in the process of replacing the battery.
Locate the cover on the bottom of the camera.
  • Locate the cover on the bottom of the camera.
  • Slide the cover towards the back of the camera.
  • Be careful—the battery can slide out on its own.
Kommentar hinzufügen
Carefully remove the exposed battery.
  • Carefully remove the exposed battery.
    • If it is difficult to remove, flip over the camera and the battery will slide out.
Abschluss
Rosario
Mitglied seit 12.04.2012
24 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 7-35, Maness Spring 2012 Mitglied von Cal Poly, Team 7-35, Maness Spring 2012
CPSU-MANESS-S12S7G35
4 Mitglieder
5 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 464
