Zum Hauptinhalt wechseln
Sony Cyber-shot DSC-T1 Flash Replacement
Was du brauchst
  1. Sony Cyber-shot DSC-T1 Flash Replacement, Battery: Schritt 1, Bild 1 von 1
    • Locate the cover on the bottom of the camera.
    • Slide the cover towards the back of the camera.
    • Be careful—the battery can slide out on its own.
  2. Sony Cyber-shot DSC-T1 Flash Replacement: Schritt 2, Bild 1 von 1
    • Carefully remove the exposed battery.
    • If it is difficult to remove, flip over the camera and the battery will slide out.
  3. Sony Cyber-shot DSC-T1 Flash Replacement, Flash: Schritt 3, Bild 1 von 3 Sony Cyber-shot DSC-T1 Flash Replacement, Flash: Schritt 3, Bild 2 von 3 Sony Cyber-shot DSC-T1 Flash Replacement, Flash: Schritt 3, Bild 3 von 3
    • Locate and remove the 3mm screws on the top and sides of the camera with the size 00 screwdriver.
  4. Sony Cyber-shot DSC-T1 Flash Replacement: Schritt 4, Bild 1 von 1
    • Pull the two halves of the camera apart.
    • Place the two halves down with the insides facing you.
  5. Sony Cyber-shot DSC-T1 Flash Replacement: Schritt 5, Bild 1 von 1
    • Find the two clips holding the motherboard to the black lens box.
    • Slide the plastic opening tool in between the ribbon and the black part of the clip, then flip it. (If difficult, your fingernail can also be used)
  6. Sony Cyber-shot DSC-T1 Flash Replacement: Schritt 6, Bild 1 von 1
    • After releasing the clips, pull out black lens box.
  7. Sony Cyber-shot DSC-T1 Flash Replacement: Schritt 7, Bild 1 von 2 Sony Cyber-shot DSC-T1 Flash Replacement: Schritt 7, Bild 2 von 2
    • Use the plastic opening tool to flip the clip.
  8. Sony Cyber-shot DSC-T1 Flash Replacement: Schritt 8, Bild 1 von 2 Sony Cyber-shot DSC-T1 Flash Replacement: Schritt 8, Bild 2 von 2
    • Grab the white part and slide it to the right until it clicks.
    • This may require some force.
    • Pull out the flash.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Paul Elrich
45 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 7-35, Maness Spring 2012 Mitglied von Cal Poly, Team 7-35, Maness Spring 2012
CPSU-MANESS-S12S7G35
4 Mitglieder
3 Anleitungen geschrieben
0Leitfaden Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 18
Letzte 30 Tage: 28
Insgesamt: 834
