Einleitung
The LCD screen is an essential components to the camera that will allow view-back of images. It is required to first remove the battery, the CCD black plastic housing, and the motherboard to access the LCD screen.
Werkzeuge
Ersatzteile
Kein Ersatzteil erforderlich.
Locate the cover on the bottom of the camera.
Slide the cover towards the back of the camera.
Locate and remove the 3mm screws on the top and sides of the camera with the size 00 screwdriver.
Pull the two halves of the camera apart.
Place the two halves down with the insides facing you.
Find the two clips holding the motherboard to the black lens box.
Slide the plastic opening tool in between the ribbon and the black part of the clip, then flip it. (If difficult, your fingernail can also be used)
Grab the white part and slide it to the right until it clicks.
Pull out the flash.
Use the plastic opening tool to flip the top clip that holds the ribbon to the motherboard unit.
Flip the motherboard unit up to expose the metal plate beneath it.
Remove the four 3mm screws shown using the 00 screwdriver.
Flip the LCD over to the other side of the camera.
Peel the tape connecting the LCD to the camera.
Remove LCD screen
