Einleitung
This guide will teach the user how to disassemble and access the AV port for replacement or installation.
Ersatzteile
Keine Ersatzteile angegeben.
The battery cover is located on the right side of the camera.
Slide the cover to expose the battery.
Ensure that the battery lines up properly with the slot in the camera.
Slide battery in.
Slide cover closed.
Remove tripod piece located at the bottom of the camera. This piece should slide out with ease.
Slide open the top panel. This is located on the top of the camera, where the power button and shutter button are.
Use plastic opening tool pop open the two ribbons attaching to the CCD module.
These are the two ribbons.
These two screws hold in the AV port.
Use Phillips screwdriver to remove screws.
