Zum Hauptinhalt wechseln
Einleitung
The back cover needs to be removed for most other repair guides in order to access more parts within the camera.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Sony Cyber-shot DSC-T9 Back Cover Replacement, Battery: Schritt 1, Bild 1 von 1
    • The battery cover is located on the right side of the camera.
    • Slide the cover to expose the battery.
  2. Sony Cyber-shot DSC-T9 Back Cover Replacement: Schritt 2, Bild 1 von 1
    • Ensure that the battery lines up properly with the slot in the camera.
    • Slide battery in.
    • Slide cover closed.
    • Battery not shown
  3. Sony Cyber-shot DSC-T9 Back Cover Replacement, Front Cover: Schritt 3, Bild 1 von 3 Sony Cyber-shot DSC-T9 Back Cover Replacement, Front Cover: Schritt 3, Bild 2 von 3 Sony Cyber-shot DSC-T9 Back Cover Replacement, Front Cover: Schritt 3, Bild 3 von 3
    • Remove screws from outside of camera. There are 6 screws total.
    • 3 screws on underside.
    • 1 screw on right side, near battery cover.
    • 2 screws on left side.
  4. Sony Cyber-shot DSC-T9 Back Cover Replacement: Schritt 4, Bild 1 von 1
    • Use screwdriver to remove screws.
  5. Sony Cyber-shot DSC-T9 Back Cover Replacement: Schritt 5, Bild 1 von 1
    • Gently pull the front cover off of the main camera.
    • All of the inner parts of the camera are attached to the back screen.
  6. Sony Cyber-shot DSC-T9 Back Cover Replacement: Schritt 6, Bild 1 von 1
    • The front cover is now removed from the camera and the internal hardware is now exposed.
  7. Sony Cyber-shot DSC-T9 Back Cover Replacement, Back Cover: Schritt 7, Bild 1 von 1
    • This is the camera without the front cover.
  8. Sony Cyber-shot DSC-T9 Back Cover Replacement: Schritt 8, Bild 1 von 1
    • Remove tripod piece located at the bottom of the camera. This piece should slide out with ease.
  9. Sony Cyber-shot DSC-T9 Back Cover Replacement: Schritt 9, Bild 1 von 3 Sony Cyber-shot DSC-T9 Back Cover Replacement: Schritt 9, Bild 2 von 3 Sony Cyber-shot DSC-T9 Back Cover Replacement: Schritt 9, Bild 3 von 3
    • Slide open the top panel. This is located on the top of the camera, where the power button and shutter button are.
  10. Sony Cyber-shot DSC-T9 Back Cover Replacement: Schritt 10, Bild 1 von 3 Sony Cyber-shot DSC-T9 Back Cover Replacement: Schritt 10, Bild 2 von 3 Sony Cyber-shot DSC-T9 Back Cover Replacement: Schritt 10, Bild 3 von 3
    • Pull apart the inner hardware from the back case by prying on the left side.
  11. Sony Cyber-shot DSC-T9 Back Cover Replacement: Schritt 11, Bild 1 von 1
    • Remove the back cover.
  12. Sony Cyber-shot DSC-T9 Back Cover Replacement: Schritt 12, Bild 1 von 1
    • The back cover is now removed from the internal hardware.
Abschluss
Stephannie Allen
231 Reputation
10 Anleitungen geschrieben
Clemson, Team 13-1, Benson Spring 2013 Mitglied von Clemson, Team 13-1, Benson Spring 2013
CLEM-BENSON-S13S13G1
4 Mitglieder
20 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 6
Insgesamt: 471
