Zum Hauptinhalt wechseln
Einleitung
This guide will teach the user how to disassemble and access the CCD module for replacement or installation.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Sony Cyber-shot DSC-T9 CCD Module Replacement, Battery: Schritt 1, Bild 1 von 1
    • The battery cover is located on the right side of the camera.
    • Slide the cover to expose the battery.
  2. Sony Cyber-shot DSC-T9 CCD Module Replacement: Schritt 2, Bild 1 von 1
    • Ensure that the battery lines up properly with the slot in the camera.
    • Slide battery in.
    • Slide cover closed.
    • Battery not shown
  3. Sony Cyber-shot DSC-T9 CCD Module Replacement, Front Cover: Schritt 3, Bild 1 von 3 Sony Cyber-shot DSC-T9 CCD Module Replacement, Front Cover: Schritt 3, Bild 2 von 3 Sony Cyber-shot DSC-T9 CCD Module Replacement, Front Cover: Schritt 3, Bild 3 von 3
    • Remove screws from outside of camera. There are 6 screws total.
    • 3 screws on underside.
    • 1 screw on right side, near battery cover.
    • 2 screws on left side.
  4. Sony Cyber-shot DSC-T9 CCD Module Replacement: Schritt 4, Bild 1 von 1
    • Use screwdriver to remove screws.
  5. Sony Cyber-shot DSC-T9 CCD Module Replacement: Schritt 5, Bild 1 von 1
    • Gently pull the front cover off of the main camera.
    • All of the inner parts of the camera are attached to the back screen.
  6. Sony Cyber-shot DSC-T9 CCD Module Replacement: Schritt 6, Bild 1 von 1
    • The front cover is now removed from the camera and the internal hardware is now exposed.
  7. Sony Cyber-shot DSC-T9 CCD Module Replacement, CCD Module: Schritt 7, Bild 1 von 1
    • This is the CCD module.
  8. Sony Cyber-shot DSC-T9 CCD Module Replacement: Schritt 8, Bild 1 von 1
    • Use plastic opening tool pop open the two ribbons attaching to the CCD module.
    • These are the two ribbons.
  9. Sony Cyber-shot DSC-T9 CCD Module Replacement: Schritt 9, Bild 1 von 1
    • Remove CCD module.
    • You may have to tug on the ribbons to remove the CCD module.
  10. Sony Cyber-shot DSC-T9 CCD Module Replacement: Schritt 10, Bild 1 von 1
    • The CCD module is now removed from the camera.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Stephannie Allen
231 Reputation
10 Anleitungen geschrieben
Clemson, Team 13-1, Benson Spring 2013 Mitglied von Clemson, Team 13-1, Benson Spring 2013
CLEM-BENSON-S13S13G1
4 Mitglieder
20 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 11
Insgesamt: 697
