Einleitung
This guide will teach the user how to disassemble and access the CCD module for replacement or installation.
Ersatzteile
Keine Ersatzteile angegeben.
The battery cover is located on the right side of the camera.
Slide the cover to expose the battery.
Ensure that the battery lines up properly with the slot in the camera.
Slide battery in.
Slide cover closed.
Remove screws from outside of camera. There are 6 screws total.
3 screws on underside.
1 screw on right side, near battery cover.
2 screws on left side.
Gently pull the front cover off of the main camera.
All of the inner parts of the camera are attached to the back screen.
The front cover is now removed from the camera and the internal hardware is now exposed.
Use plastic opening tool pop open the two ribbons attaching to the CCD module.
These are the two ribbons.
2 weitere Nutzer haben diese Anleitung absolviert.
