Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This guide will allow the user to remove the front cover of the camera, necessary for most other steps.
Ersatzteile
Keine Ersatzteile angegeben.
  1. The battery cover is located on the right side of the camera.
    • The battery cover is located on the right side of the camera.
    • Slide the cover to expose the battery.
  2. Ensure that the battery lines up properly with the slot in the camera.
    • Ensure that the battery lines up properly with the slot in the camera.
    • Slide battery in.
    • Slide cover closed.
    • Battery not shown
  3. Das Essential Electronics Toolkit
    Die wichtigsten Werkzeuge in unserem kompaktesten Kit.
    Jetzt kaufen
    Jetzt kaufen
  4. Remove screws from outside of camera. There are 6 screws total. 3 screws on underside. 1 screw on right side, near battery cover.
    • Remove screws from outside of camera. There are 6 screws total.
    • 3 screws on underside.
    • 1 screw on right side, near battery cover.
    • 2 screws on left side.
  5. Use screwdriver to remove screws.
    • Use screwdriver to remove screws.
  6. Gently pull the front cover off of the main camera.
    • Gently pull the front cover off of the main camera.
    • All of the inner parts of the camera are attached to the back screen.
  7. The front cover is now removed from the camera and the internal hardware is now exposed.
    • The front cover is now removed from the camera and the internal hardware is now exposed.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Stephannie Allen
210 Reputation
10 Anleitungen geschrieben
Clemson, Team 13-1, Benson Spring 2013 Mitglied von Clemson, Team 13-1, Benson Spring 2013
CLEM-BENSON-S13S13G1
4 Mitglieder
20 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 6
Insgesamt: 295
