Zum Hauptinhalt wechseln
Einleitung
The sliding lens cover is on the front of the camera, and moves vertically to hide or expose the lens and flash. It may need to be replaced if it becomes stuck.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove screws from outside of camera. There are 6 screws total. 3 screws on underside. 1 screw on right side, near battery cover.
    • Remove screws from outside of camera. There are 6 screws total.
    • 3 screws on underside.
    • 1 screw on right side, near battery cover.
    • 2 screws on left side.
  2. Use screwdriver to remove screws.
    • Use screwdriver to remove screws.
  3. Gently pull the front cover off of the main camera.
    • Gently pull the front cover off of the main camera.
    • All of the inner parts of the camera are attached to the back screen.
  4. The front cover is now removed from the camera and the internal hardware is now exposed.
    • The front cover is now removed from the camera and the internal hardware is now exposed.
  5. The front sliding lens cover.
    • The front sliding lens cover.
  6. Remove four screws using Phillips located on the inside of the front cover. Remove four screws using Phillips located on the inside of the front cover.
    • Remove four screws using Phillips located on the inside of the front cover.
  7. Remove front sliding lens cover. Remove front sliding lens cover.
    • Remove front sliding lens cover.
  8. The front sliding lens cover is now removed and may be repair or replaced. The front sliding lens cover is now removed and may be repair or replaced.
    • The front sliding lens cover is now removed and may be repair or replaced.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Stephannie Allen
231 Reputation
10 Anleitungen geschrieben
Clemson, Team 13-1, Benson Spring 2013 Mitglied von Clemson, Team 13-1, Benson Spring 2013
CLEM-BENSON-S13S13G1
4 Mitglieder
20 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 3
Insgesamt: 829
