Einleitung
This guide will allow the user to access the motherboard for installation, replacement, or removal.
Was du brauchst
The battery cover is located on the right side of the camera.
Slide the cover to expose the battery.
Ensure that the battery lines up properly with the slot in the camera.
Slide battery in.
Slide cover closed.
Remove screws from outside of camera. There are 6 screws total.
3 screws on underside.
1 screw on right side, near battery cover.
2 screws on left side.
Gently pull the front cover off of the main camera.
All of the inner parts of the camera are attached to the back screen.
The front cover is now removed from the camera and the internal hardware is now exposed.
Remove tripod piece located at the bottom of the camera. This piece should slide out with ease.
Slide open the top panel. This is located on the top of the camera, where the power button and shutter button are.
The LCD is now removed from the camera, although attached by a ribbon at the bottom of the camera.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Flip camera to other side.
Use tweezers to peel off black sticker, located in middle of the motherboard.
Use plastic opening tool pop open the two ribbons attaching to the CCD module.
These are the two ribbons.
These two screws hold in the AV port.
Use Phillips screwdriver to remove screws.
The battery cover is located here.
Pull away from camera to remove.
Grip on the top and bottom.
Pull up and out to remove motherboard and attached parts.
Flip motherboard parts to position shown.
There are three ribbons still attached to the motherboard.
Pull these three ribbons to remove remaining parts from motherboard.
3 weitere Personen haben diese Anleitung absolviert.
