Zum Hauptinhalt wechseln
Sony Cyber-shot DSC-TX55 LCD Screen Replacement
Was du brauchst
  1. Sony Cyber-shot DSC-TX55 LCD Screen Replacement, LCD Screen: Schritt 1, Bild 1 von 3 Sony Cyber-shot DSC-TX55 LCD Screen Replacement, LCD Screen: Schritt 1, Bild 2 von 3 Sony Cyber-shot DSC-TX55 LCD Screen Replacement, LCD Screen: Schritt 1, Bild 3 von 3
    • Slide open the battery cover in the direction that the arrows on device are pointing.
    • Flip the blue battery lock to eject the battery.
    • Remove the battery from the device.
  2. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: Schritt 2, Bild 1 von 1
    • Using your Phillips #00 screwdriver, remove all four 0.3 cm screws that are located on both ends, as well as the bottom of your Cyber-Shot.
    • Make sure that your screws are placed on a flat, still surface so they do not roll away.
  3. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: Schritt 3, Bild 1 von 1
    • Gently pull away the back end of the camera where the LCD screen is located.
    • Remove the metal frame that is located around the LCD screen.
  4. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: Schritt 4, Bild 1 von 1
    • Remove the front cover.
  5. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: Schritt 5, Bild 1 von 1
    • Gently remove the lens from the device.
    • The lens will hang on by the orange strips, be careful not to tug on the lens.
  6. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: Schritt 6, Bild 1 von 2 Sony Cyber-shot DSC-TX55 LCD Screen Replacement: Schritt 6, Bild 2 von 2
    • Gently slide the LCD screen using very light pressure to the right until it pops open.
  7. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: Schritt 7, Bild 1 von 1
    • The LCD screen will open to the right.
    • Remove the orange tab from the device.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Megan East
555 Reputation
5 Anleitungen geschrieben
Sam Houston State, Team 2-5, Blackburne Fall 2015 Mitglied von Sam Houston State, Team 2-5, Blackburne Fall 2015
SHSU-BLACKBURNE-F15S2G5
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 21
Insgesamt: 1,728
