Was du brauchst
Slide open the battery cover in the direction that the arrows on device are pointing.
Flip the blue battery lock to eject the battery.
Remove the battery from the device.
Using your Phillips #00 screwdriver, remove all four 0.3 cm screws that are located on both ends, as well as the bottom of your Cyber-Shot.
Gently pull away the back end of the camera where the LCD screen is located.
Remove the metal frame that is located around the LCD screen.
Gently slide the LCD screen using very light pressure to the right until it pops open.
2 weitere Personen haben diese Anleitung absolviert.
