Einleitung
This repair guide will instruct you to disassemble the Sony Cyber-shot DSC W150 to replace a scratched or broken back casing. A screwdriver will remove a total of 8 screws to remove the back casing successfully. Once the screws are removed, you can use your hands to pull apart the back casing.
Was du brauchst
On the right side of the camera, remove the two silver screws using the screwdriver.
On the left side of the camera, remove the two silver screws using the screwdriver.
Gently detach the back cover by holding onto both sides of the camera and pulling them apart.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
