Einleitung
This guide will instruct you on how to remove the front casing on the Sony Cyber-shot DSC W150. To successfully remove the front casing, a screwdriver should be used to remove a total of five screws. Once the screws are removed, you can use your hands to pull the front casing from the camera.
Was du brauchst
On the right side of the camera, remove the two silver screws using the screwdriver.
On the left side of the camera, remove the two silver screws using the screwdriver.
Gently detach the back cover by holding onto both sides of the camera and pulling them apart.
After removing the screws, gently pop open the plastic piece, as shown by firmly pulling it with your fingers.
After popping open the plastic piece, there is a screw that needs to be removed.
Remove the screw connecting the front casing to the electrical components.
On the casing on the opposite side of the camera, gently loosen and remove the casing by firmly pulling with your fingers.
Remove the two screws connecting the front casing to the electrical components using a screwdriver.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
