Einleitung
This guide will instruct you on how to replace a defective LCD screen in the Sony Cyber-shot DSC-W150. To successfully remove the screen a screwdriver is used to remove a screw, a spudger, and tweezers to remove electrical ribbons.
Was du brauchst
On the right side of the camera, remove the two silver screws using the screwdriver.
On the left side of the camera, remove the two silver screws using the screwdriver.
Gently detach the back cover by holding onto both sides of the camera and pulling them apart.
After removing the screws, gently pop open the plastic piece, as shown by firmly pulling it with your fingers.
After popping open the plastic piece, there is a screw that needs to be removed.
Remove the screw connecting the front casing to the electrical components.
On the casing on the opposite side of the camera, gently loosen and remove the casing by firmly pulling with your fingers.
Remove the two screws connecting the front casing to the electrical components using a screwdriver.
Using a screwdriver, remove the last screw holding the LCD/control panel to the rest of the camera on the right-hand side.
Paying careful attention to the right side's electrical wiring, gently pull the left side of the LCD plate away from the rest of the camera.
Using a spudger, wedge the flat-tipped end between the black bar and the circuit board.
Carefully lift the black bar into the vertical position.
Use tweezers to carefully pull the larger electrical ribbon from its circuit board port.
Use tweezers to pull the smaller electrical ribbon carefully from its circuit board port.
Desolder the small electrical ribbon that connects the control panel to the LCD screen.
Now the LCD/control panel is completely removed from the part and ready to be replaced.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
