Einleitung
Disassembling Sony Cybershot DSC-W5 in order to get to the battery terminal so that it can be replaced.
Was du brauchst
Remove Memory Stick Pro from the card reader slot on the bottom of the camera.
Remove both batteries.
Remove the single visible screw from both sides of the camera.
Remove the two screws that are adjacent to the warning label, which is on the underside of the camera.
The LCD screen sits in two slots; one on the bottom, and one on the left edge.
Slide LCD screen from the two slots.
To remove the LCD screen, detach the orange cable from the board.
If needed, replace the LCD screen.
Remove the two screws holding down the steel back plate.
Remove steel back plate.
Disconnect the flash cable (black and white wires) before completely removing the front case.
Gently start to remove the case.
Once the cable is free, set aside the front case.
The speaker should now be clearly seen on the underside of the camera.
Gently unplug the speaker from the motherboard.
Replace the speaker.
Remove the orange cable connecting the battery terminal to the motherboard.
5 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
Clean the little nobs in the pattery-pack and problem solved! I also removed the black plastic ring that was on the +pole inside.
