Zum Hauptinhalt wechseln
Sony Cyber-shot DSC-W50 Front Case Replacement
Was du brauchst
  1. Sony Cyber-shot DSC-W50 Front Case Replacement, Front Case: Schritt 1, Bild 1 von 3 Sony Cyber-shot DSC-W50 Front Case Replacement, Front Case: Schritt 1, Bild 2 von 3 Sony Cyber-shot DSC-W50 Front Case Replacement, Front Case: Schritt 1, Bild 3 von 3
    • Remove the rightmost screw on the bottom of the camera with the screwdriver.
    • Remove the bottom left screw with the screwdriver.
    • Remove the top left screw with the screwdriver.
  2. Sony Cyber-shot DSC-W50 Front Case Replacement: Schritt 2, Bild 1 von 1
    • Flip the camera over to expose its right side.
    • Remove the screw with the screwdriver.
  3. Sony Cyber-shot DSC-W50 Front Case Replacement: Schritt 3, Bild 1 von 2 Sony Cyber-shot DSC-W50 Front Case Replacement: Schritt 3, Bild 2 von 2
    • Flip the camera to expose the left side with the wrist strap.
    • Remove the top screw with the screwdriver.
    • Remove the bottom screw with the screwdriver.
  4. Sony Cyber-shot DSC-W50 Front Case Replacement: Schritt 4, Bild 1 von 1
    • Lift the side panel of the camera up to release the front case.
  5. Sony Cyber-shot DSC-W50 Front Case Replacement: Schritt 5, Bild 1 von 1
    • Lift the front case up gently to remove it completely.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 38
Insgesamt: 1,140
