Einleitung
Outline what you are going to teach someone how to do.
Was du brauchst
Remove the two Phillips head, 2.93 mm long screws at the bottom of the camera.
Turn the camera sideways so the left side is fasning upwards, remove the two Phillips head, 2.93 mm screws.
Now turn the device so the opposite side is fasning upwards and remove the last two Phillips head, 2.93 mm screws.
To remove the front cover, use a plastic opening tool gently pry the top cover.
Then gently lift the cover off.
To remove the back case cover from the body.
First use a plastic opening tool gently pry along the side of the camera.
Then slowly and gently lift the cover off.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
