Zum Hauptinhalt wechseln
Sony Cyber-shot DSC-W570 Case Cover Replacement
Was du brauchst
  1. Sony Cyber-shot DSC-W570 Case Cover Replacement, Case Cover: Schritt 1, Bild 1 von 1
    • Begin by facing the camera bottom side up to reveal the two 2.93 mm long screws
    • Remove these two screws using a Philips #00 screwdriver
    • Make sure the battery compartment door is in lock position.
  2. Sony Cyber-shot DSC-W570 Case Cover Replacement: Schritt 2, Bild 1 von 1
    • Turn the camera sideways on its left side making sure the two 2.93 mm long screws are facing upwards
    • Remove the two 2.93 mm long screws using a Phillips #00 screwdriver
    • Keep all screws on stable surface to not loose them
  3. Sony Cyber-shot DSC-W570 Case Cover Replacement: Schritt 3, Bild 1 von 1
    • Turn the camera on its right side making sure it is facing upwards
    • Remove the last two 2.93 mm long screws using a Phillips #00 screwdriver
  4. Sony Cyber-shot DSC-W570 Case Cover Replacement: Schritt 4, Bild 1 von 2 Sony Cyber-shot DSC-W570 Case Cover Replacement: Schritt 4, Bild 2 von 2
    • Face the device with the camera lens facing upwards
    • Now that all the screws are unscrewed, the plastic opening tool will be used to remove the front cover.
    • Gently pry off each corner of the cover to remove it
    • Once all corners are pried off, gently lift off the cover and place it on the side
  5. Sony Cyber-shot DSC-W570 Case Cover Replacement: Schritt 5, Bild 1 von 2 Sony Cyber-shot DSC-W570 Case Cover Replacement: Schritt 5, Bild 2 von 2
    • Flip the device, making sure the screen is facing upwards
    • The back case should now be visible and ready to remove
    • Use the plastic opening tool to gently pry all along the corners and sides of the camera.
    • Gently lift off the entire back cover and place it on the side
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
USF Tampa, Team 9-1, Brown Winter 2015 Mitglied von USF Tampa, Team 9-1, Brown Winter 2015
USFT-BROWN-W15S9G1
5 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 22
Letzte 30 Tage: 68
Insgesamt: 1,096
